Hi all,
I was hoping someone might provide some thoughts on an issue I'm having with my images. I did a two-night session on the Jellyfish nebula but the center of the Integration seems to be overly dark compared to other areas. I've noticed it's also a little on other images as well. I used AstroPixelProcessor (APP) to calibrate the frames and noticed the NormalizationMap and RejectionMap also contains this pattern. There's just something going on in the middle. Could it be something going on with the camera e.g. frost?
Attached is the RejectionMap and Integration out of AstroPixelProcessor (APP).
Equipment used:
OTA: Explore Scientific 102mm f/7 Triplet ED APO Refractor
Cameras: ZWO ASI294MC Pro
Filter: Optolong L-eNhance
Cooled to -10 degrees C.
Many thanks in advance for any thoughts.
Jairo
