Hi, the thing is that the asi 1600 has such a low noise level that one can make short exposures even with nebulas.
My question was the following
If I remember correctly, you have shown in your link with an f4 scope, and a stack of the crab nebula where each image has 10 seconds exposure time, that you get a better snr with lowest read noise setting.
My question is whether this holds at all appertures.
Say we have the same object, the crab nebula, like in your example, but now at f10 instead of f4.
I would either need a longer exposure or a higher number of images to get the same snr and signal.
Assume I chose a longer exposure. f10 is approx 3 aperture steps away from the f4 of your system. So i guess, in order to get the same signal, I would need a stack of the same number of images, and each image with an exposure time of 10*2*2*2=80 sec .
Is then, with this longer time for each image, still the lowest read noise setting giving a better snr than unity gain?
Or does the noise get overhand, reducing the snr?
Now assume, i want to get the same snr and the same signal with more images instead of a longer exposure. So how many images would I need, if I have again the crab nebula, 10 sec exposures and an f10 scope instead of your f4?
