gundamrx91 wrote:
I'm sorry but i remember at the first execution of the program the guide settings were different from the last firmware update, so every time I have to check every single parameter because I don't know if it's right.
Giuseppe
Hey Giuseppe, the values will be saved on your ASIAIR device after you used. BUT there is no default values for the first time using. As you said, after firmware updated, may some values were changed cause the new features.
