Moon with 300mm/f5@f10 Skywatcher/ASI 290MM/IR Pass filter
Clavius
Sinus Iridum (mosaic)
South pole of the Moon (mosaic)
Which mount do you use?
EQ-8 mount
Ok, thank you very much
Good evening - did you use a Barlow?
Looking to acquire a Tele Vue 4x PowerMate with a SE6 (AVX) or SE8 (EQ-6) and mate it with the ASI290.
Would appreciate any wisdom, experience, software you may be using for your Moon images.
Thanks, Jim
