I have a few questions for people using the EAF.
- Do you like the EAF? Does it perform well doing temperature compensation?
- How stable is the software? Do you have any problems?
- With the EAF attached to the scope can you "manually" adjust focus or do you need to use the Hand Controller or focus control software?
- It looks like you can not use the Hand Controller and temperature probe at the same time. Is this correct?
