Aggressiveness settings accessed on the guide icon (not on the guide camera tab), tap the graph icon, and you'll see the guide graph. The top line of the graph has the aggressive settings - tap the RA or DEC - values to adjust these via +/-.
For my AVX mount (standard, no tweaking, old bearings) with a 81mm William Optics refractor & guide scope, with flattener, ASI071MCC - fair amount of weight.
If I'm not slewing or guiding at a altitude, find the aggressiveness settings of 65-70%, 2000ms (max guide adjustment), and using an exposure of 2 seconds provides me with an RMS of less than 1.00 (under ideal conditions). When it's windy, things don't work well, and then there's the occasional bumping of the mount.
I've recently been using the dithering - works well but don't have a recommendation yet on the best practices.
Hope this helps - will post the guide information from my next session.
What I'd like to know is how to turn on and save the guide log - did this logging get removed from the last upgrade - have files in the log file from earlier sessions but haven't see any since the latest upgrade.
Jim
