Katherine.Tsai wrote:
Does the camera still work well in Win7?
Or it just drop frames in Win10?
Please try this camera in ASICAP, the original ASI software.Check if the problem stills.
Hi Katherine,
Yes. the camera still works without any noticeable issues in Win7. Frames only drop when I attach it to may Win10 laptop.
I am attaching a screen capture showing the performance in Windows 7 using ASC Studio, ASICap v.1.0 I also get comparable performance using older versions of ASICAP (1.6.1 and 1.6.2). You can see the frame rates, and relative low rates of dropped frames in the status line at the bottom left. All the tests were done in RAW16 mode.
But, when I attach the camera to Windows 10, the frame rate falls and the dropped frame count rises very dramatically. You can see that data in the lower left of the screen captures that I made with ASI Studio ASICap running in Windows 10. I attach a screen captures -one for MONO8, Things are the same for MONO16. Performance is about as poor with either bit-depth.
For reference, I attach screen snip from my Device Manager for Win7. You will notice a specific controller for USB 2.0. Which does not appear in Win 10 device manager. There I have only Intel(r) USB 3.1 eXtensible Host Controller 1.10 (Microsoft) with USB Root Hub (USB 3.0), and UCM-UCSI ACPI Device. I wonder if this causes problems for USB 2.0. The ASCAP software seems to know that USB 2.0 is being used, but does seem to struggle to read the frames.
Thanks for your assistance. (I hope that you and everyone at ZWO are well and in good health.)
MarkO
