My guiding wasn't that good so I'm trying to setup my cables & settings correctly.
Telescope is a WO 61mm focal length 369mm
I have an EQ6-R mount with no USB port.
I use a EQMOD cable from the ASIAIR to the mount (I don't use the handset)
I set the slew rate to 1 before going into the guide function.
I use the ASI120mm mimi camera with ZWO 30mm guide scope which has a focal length of 120
I verify the the guide scope focal length is correctly listed as 120mm (first time it defaulted to 30mm & I didn't change it so this was an issue)
Question is - Can I connect the ASI120mm mimi Guide Camera w/30mm scope to the ASIAIR USB and not use the ST4 cable/port to connect to the guide port on the mount or would this not send the needed info to the mount needed to guide?
I have read if you use the ST-4 connection from the guide camera to the mount you have to then change the scope to "On-Camera-ST4" for guiding and then when finished imaging change it back to your actual scope for the next Goto.
Thanks.
