I have an ASI2600MC Pro on back-order from OPT and have some questions.
- Are Flat-Darks necessary? Can you get away with standard Darks, BIAS and Flats?
- Is Offset automatically set?
- Are you still happy with the ASI2600MC Pro?
-Yes the calibration frames are still needed.
- here is a defalut offset set.
That was not the question.
Does the ASI2600 require Flat-Darks or just Flats. Which should I use?
Both are needed.
For calibration, here is a simple illustration.
