Is an IR Cut Filter required for the ASI2600?
The manual states in text that it has an IR Cut Filter but the graph says otherwise. Did ZWO post the wrong graph in the manual? Does the ASI2600 require an IR Cut Filter?
ASI2600MC Pro is using IR cut protective glass. Sorry we put the wrong graph on the manual, we will correct it soon.
Thank you for the feedback!
Please refer to the new manual.
