FYI - I think the issue with the scope not returning to the correct "home" position has something to do with the EQmod/Skysafari connection.
I imaged several hours last night. Initially all my Go-to's worked perfectly, and my scope returned to the "home" position with no problems after every target. However, when I later connected to Skysafari my first "Go to" with Skysafari connected and seemed to worked fine, but after that the scope would no longer return to the correct "home" position. Furthermore, when I attempted another "go-to" from that position ASIair had difficulty centering the target.
I then turned my mount off in my ASIair app, selected only "EQmod" from the mount list without Skysafari, turned the mount back on in the application and my scope returned back to the correct "home" position and performed later "Go-to"s with no further problems.
Anyway, I hope this helps.
BTW - Wo juede ASIair, shi feichang hao de!
Xiexie nimen hao hao de gongzuo a!
Ron
