Hi
Is it possible to reset the defaults in ASICAP?
In particular I would like to software to default to RAW16.
On several occasions I have forgotten to check this resulting in the capture being in RAW8
Thanks
Frank
Sorry for that.
ASICap used for planetary photograph, so its format is set default to RAW8.
If you use RAW16 a lot, you could use ASIImg. ASIImg mainly used for deep sky photograph. Its format is set default to RAW16.
Thank you.
