artem wrote:
AUSTRIA
IPAD PRO
ASTROPHYSICS MACH1GTO GTOCP4
ASI1600MM+ASI 120 MINI as GUIDER CCD.
EFW Mini
Guiding and CALIBARTION end with STAR DiD NOT MOVE ENOUGH or so.. but the biggest issue is, that whenever I calibrate at the end of the calibration process and after the error is shown, the mount mobes few degrees and stops and again moves in same direction again..
I am using the latest BETA ASIAIR..
Thank you
Martin
Hey Martin, please check the guide rate is 0.5x or higher, and yes, update to the 1.4.3 official release.
