I own a ZWO ASI1600MM-Pro which I use with a ZWO mini guide scope and ZWO ASI120mini, ZWO-EAF and 135mm lens all controlled with a ZWO-ASIair. In order to keep the weight to a minimum (dodgy hands) I use a manual filter holder.
Please can I request that ASIair allows you to select a Manual Filter option thus allowing you to input the filter name in a sequence, e.g. H, O, etc.
Currently, following capture, I have to use a third party software to modify/edit the .fit header to include filter name before certain calibration software will recognise the files as legitimate .fit files. This problem also arises with Flat files - no filter name and the software refuses to use the calibration files.
Thank you for considering my request.
P.S. The ASIair has absolutely transformed imaging for me - easy to setup , easy to use, consistently reliable and stable. Thank you for a great product.
