Hi,
About a year ago I bought a ASI1600mmPro Camera and LRGB and NB filters.
1. What is the correct orientation for the LRGB and NB filters?
2. How can you tell which is the Red/Green filter as they look almost identical?
Regards
John
There is no difference in the orientation of the LRGB and narrowband filters.
If you holds a framed filter, there is an LRGB mark on the frame.Or you can check the logo on the package.
These are unmounted ZWO 36mm filters (LRGB & NB) and there are no marking on the edge of the filter. Orientation does matter, as one side is more reflective than the other ...
1.You can follow the attachments.(ps. Both side of new OIII filter will be fine.)
2.You can judge the LRGB filters by their color.
"1.You can follow the attachments.(ps. Both side of new OIII filter will be fine.)"
Which attachments?
