a.cidadao wrote:
Hi all, can you please tell us about the availability of a detailed tutorial on using DSLR cameras through asiair pro?
I personally have a Canon 7D (first gen).
Thanks in advance!
António
p.s. I would definitively vote for the development of a external wifi dongle for asiair pro...
The DSLRs can only be used as the Main Camera. When using, connect the DSLR to the ASIAIR device directly through the data cable. Before opening in the app, you need to set the following options.
Shooting Mode: M
Shutter Mode: Bulb
Image Format: RAW (Only, not RAW+JPEG)
Image Quilty: L (Largest)
Additionally, turn off any power-saving feature of the camera that might cause it to hibernate or sleep. Turn off Noise Reduction, Mirror Lock settings in the camera.
If you are going to do Autorun, please make sure that there is enough space on the SD card (refer to the “Estimated Space” of the ASIAIR Autorun setting interface, which should be greater than that value) and the battery is fully charged.
The support of external WiFi dongle is on the way.
