Hello, i've been doing 300 and 600 second exposures during my last sessions and i'm noticing abnormal strange black donuts on my frames.
These donuts appears directly when shooting in raws FIT files and the postprocessing does not remove these defaults correctly soit appears to be an issue.
I tested 4 or 5 sessions during two weeks cooling the camera at -10 °C and this problem appears constantly.
I'm shooting with APT and tested unity gain, lower read noise and high range modes and it has no consequences on the problem.
I'm attaching a file sample so that you can see this strange thing and hope someone knows a solution to remove these dark donuts.
Thank you
Mourad
