jaygpoo wrote:
Hi. I am a asiair convert and very pleased to get the asiair pro. I set it up and all has been working as it should with the wifi range problem being the only sad point. Now I needed to use another scope on my eq5 mount that uses different gear so set it up and found the eqmod cable would not connect to the mount? After some time asking many experts I found that the asiair had asigned a com port to the eqmod cable and my laptop needed to have the com port re assigned which I did and all worked. NOW I go back to the asiar set up and scope and connect all of it up to find that although it connected to start with and moved to a target it woukd not return to park and I had no control over the mount. The com port is clearly the problem but I can not change it back. Can the asiar be factory reset? I have moved the cable to different usbs but to no effect. Will I have to buy a new eqmod cable just for the asiair. I now have a great product but can not use it because I connected the eqmod cable back to my laptop and back again to the asiair? If I have made the. unit or cable usless its through a small lack of computor com port knowledge. Jay
Hey Jay, the problem is now the mount can not back to the home position, right? Others work normally.
Please check if you power up the mount at Home Position. http://eq-mod.sourceforge.net/docs/MountHomePosition.pdf
