image flipping problem asi1600mm
I have a c9.25 with cgx and hyperstar. I use an asi1600mm on it. Yesterday I tried "center here" and plate solve on m81 but I had a funny problem. Each time I try, the platesolver tells me that it succeeded with an error of 20 pixels in Ra and 10 in Dec when in fact the point that I asked it to center is far opposite. I don't know why. I tried with ASTAP, PlateSolve2 and astrometry.net. it's always the same thing . the telescope leaves on the wrong side and all the platesolver tell me that the plate is solved while my target is out. I used target offset, I used synchronization, it was the same thing. on cpwi I tried with 1 alignment star to avoid the problems of the pointing model but it's still the same. it’s as if the camera doesn’t read the pixels the right way. I tried with my asi 294mc instead and everything works ... I have try with prism v10 and it is the same thing prism is wrong in the orientation of the camera. I do not know what to do . especially that it worked perfectly so far. I also reinstalled the drivers and nothing works. tonight I pointed to the moon and normally I should see it in an east / west mirror with my hyperstar but there I saw it exactly in the same direction as with the naked eye. I use sequence generator pro for a long time, I did not rotate with the software. anyway i have the same error with sharpcap and prismv10 .I'm lost
I
