Hello i red on the manual that EAF has a 35mm diameter motor with 5760 step. so, does it menas that I need to use 35*3,14/5760 =0,01908 has STEP SIZE value for SGP??
Thanks.
Sorry that's not what it means. When you set the step size in SGP, you should set the integer like 10, 20, 50 or more, which matches the step size in EAF.
