Has anyone found a fix for this issue yet? I have reached out to ZWO help desk, the internet and Sky-Watcher and no one seems to be able to help me. Below is a list of things I have tried and a few others I didn't list and still the same issue and after speaking with Sky-Watcher, this is a ZWO issue because the DST issue happens when I'm connected to my EQ350 Pro mount and my Star Adventurer GTi. I really need some help here because everything worked fine right up until March and then it stopped working and I'm to the point of throwing my ASIAIR Plus at a brick wall.
The items below that mention the SynScan hand controller are from suggested fixes online to set the time, date and other parameters in the mount and that will change the info in the ASIAIR app, it did not work as you can see below or I wouldn't be here asking for help.
- I have given the iPad app location permission all the time
- I have tried connecting to the app with my phone
- I have tried connecting to the app with my wife's iPad and phone
- I have reset the ASIAIR plus several times
- I have reset the firmware of my ASIAIR
- I have uninstalled and reinstalled the ASIAIR app
- I have reset the SynScan control to factory settings
- I have updated the firmware on the SynScan hand controller
- I have factory reset any and all settings on my Sky Watcher CQ350 Pro
- I have tried syncing the app to the mount
- I have tried not syncing the app to the mount
- I have tried both DST on and DST off
- I have tried station mode and not station mode
- I have tried to set the time in the SynScan hand controller an hour ahead
- I have tried to set the time in the SynScan hand controller an hour behind
- I have tried to set the time in the SynScan hand controller an hour ahead with DST on
- I have tried to set the time in the SynScan hand controller an hour ahead with DST off
- I have tried to set the time in the SynScan hand controller an hour behind with DST on
- I have tried to set the time in the SynScan hand controller an hour behind with DST off
- I have tried manually changing the time on my iPad to try and trick the ASIAIR app into thinking it was in a different time zone to offset the DST error even though it knows what time zone I am in
Why don't we the people have the power to press a button within the app that turns DST on and off when we need to since clearly the app knows the correct time. I know it does because it shows me the time when I start the app so why does the app forget everything it already knows once I try to use it.
Also the support I am getting from ZWO isn't really help.
