I have an ASI6200MM-pro that appears to cause a USB problem in my computer. When I connect the ASI6200 to my computer I get the following USB error in device manager (Windows 10).
As you can see I also have an ASI2600MC and ASI174 mini. All three cameras connect to the computer, but they will only download at USB2 speeds, not USB3.0. The cameras are all connected to a high quality powered USB 3.0 hub, and the hub is connected to an Intel NUC miniPC USB3.0 port.
This problem only happens when the ASI6200 is connected to the USB hub. It does not happen when only the ASI2600 is connected to the hub.
I have a spare NUC miniPC, and the exact same issue happens with that computer as well. So the ASI6200 is causing some sort of USB issue in two different computers.
I would appreciate any ideas about what the problem is or how to fix it.
