Nordstern wrote:
I have a problem. auto run takes a picture and then it doesn't go on? does that not work with the dither function when guiding?
Hey Nordstern, did it shows the Dither is setting and keep that msg then stop Autorun? If so, please check the Dither settings or try to disable the Dither.
