Hi all, while astro activities are not possible, just want to share my mobile setup for terrestrial IR-photography with ASI290MM and ASI183MM cameras and ASICAP android apk.
The 183MM has a 10-22mm Canon lens adapted via the Astromechanics focuser, in this case user just to connect the lens, and has a frontal Cokin 89B filter.
The 290MM has an old manual Pentax 50mm 1.4 lens attached via a Teleskop-Express adapter with an Astronimik proplanet IR filter behind the lens.
Cell phone is an old Nokia 8, attached to a powered Satechi USB hub (type C, slim) and a 20000mAh Devia power bank.
Cell phone is attached to a Manfrotto clip holder mounted onto a tiny CB2 Cullmann photo head.
Cameras are attached to hub through a short USB2 cable from ASI.
ASICAP for android for maximum portability.
Power bank has a long cable to be able to stay in my pocket.
Just two images, a 50% reduced 1x1 binned 290MM full frame, and a HD 1x1 crop (also 50% reduced) from the 183MM
The latter, besides its astronomical use, is a great camera for terrestrial IR photography with wide-angle lens.
Wish ASICAP for android was updated for higher stability and had simple slow-rate, no-alignment, live-stacking capabilities.
Best
António
