billx wrote:
I have original AIR and latest update, and have gotten it to work well with ASI cameras. But when I try to use it with my Nikon D850, I can take preview exposures, but autorun locks up when I try to use it. It will take one exposure, and then stops and locks up. Any idea what the problem is?
Hey billx, I just tested the D850 here, there is no issue. So, let's check:
#1 The settings of your D850,
The DSLRs can only be used as a Main Camera. When using, connect the DSLR to the ASIAIR device directly through the data cable. Before open in the app, you need to set the following options.
Shooting Mode: M
Shutter Mode: Bulb
Image Format: RAW (Only, not RAW+JPEG)
Image Quilty: L (Largest)
Additional, turn off any power-saving feature of the camera that might cause it to hibernate or sleep. Turn off Noise Reduction, Mirror Lock settings in the camera.
If you are going to do Autorun, please make sure that there is enough space on the SD card (refer to the “Estimated Space” of the ASIAIR Autorun setting interface, which should be greater than that value) and the battery is fully charged.
#2 Check the Autorun - Target name settings, just change it to only number or only a-z chars. Please try this.
