Hi,
My EAF has a measure backlash of around 115 steps. If I detach the coupling from the telescope focuser, I can move the coupling a few millimeters freely, which I assume is the cause of backlash. I have double checked and made sure all the connections to the coupling are tight, so the backlash must be coming from the stepper motor itself. Is this amount of backlash normal? Even with backlash compensation on the ASIAIR, it's quite difficult to make precise focus adjustments.
