That's a dew/moisture problem. My 294 behaves the same way.
You can avoid it, if you set the target temperature a few degrees
higher (about 20 degrees below environment temperature).
That's not perfect, of course, but better than loosing frames …
As soon as the nights here in Germany are too short and too bright
to take photos, I will try to dry the desiccant tablets and install
a camera window heater. I hope this solves the Problem.
