I'm having trouble connecting ASIAIR to a new AZ-EQ6 Synscan V5 hand controller.
I use the procedure stated in this page https://astronomy-imaging-camera.com/tutorials/how-to-connect-asiair-to-your-skywatcher-mount.html
I think the AZEQ6 have the same hand controller of the EQ8... so, I'm using (maybe I'm wrong) an old USB cable from a single ASIAIR USB port to the USB female port on the hand controller (controller wich is connected to the mount via hand control cable plugged in the mount and the controller itself).
When I go in the Telescope Settings on ASIAIR app, i select "EQMOD Mount" "Serial" Baud (various numbers... default "9600" or "115200" or others) but no way I can connect the mount to ASIAIR.
What I'm doing wrong?
PS: before trying to connect the mount to ASIAIR, i did a star alignment and still doesn't work.
