Hi,
Thanks for your reply.
The camera works fine in ASIStudio.
I use TheSkyX (TSX) because I prefer native X2 plugins over ASCOM. I also use CCD Autopilot (CCDAP) for automation which integrates well with TSX (TSX controls everything) and does not require ASCOM. Bottom line is that I would prefer not to use ASCOM. HOWEVER, I will try the ASCOM driver tonight and see what happens.
Also, since my original post I reinstalled the latest X2 drivers from your website. Interestingly, the filename was the same (2.0.2.9), but it changed the "Driver version" in the TSX camera dialogue from v2.8 to v2.9.
After updating from v2.8 to v 2.9, the memory errors are now much less frequent but they still occur randomly during imaging and focusing. When they occur during an automated CCDAP session, it causes the session to abort which is very discouraging because it ruins an entire evening of imaging. For example:
00 Leo Triplet, exposing...
00 I, CCDSoft2XAdaptor.CCDSoft5Camera.1 says Error: memory error. Error = 205. <=== CCDAP ERROR MESSAGE
00 Clear, Dry, Dark, Sky: -27.5°C, Ambient: 7.4°C, RH: 48%, Wind: 2.0 KPH,@ 12 AM,
00 *** Aborting session due to data acquisition failure
Again, if I do not use the filter wheel then the camera works without problem in TSX & CCDAP so it seems there may be some interaction between the plugins for the filter wheel and camera?? I will let you know what happens when using the ASCOM driver for the filter wheel.
Thanks!
Steve
