Hi Moson,
Many thanks for your advice. Problem resolved - in case it might help anyone else, this was the solution:
- Connected to a different computer and the drivers loaded immediately in SGP! So, definitely the cause was related to the original computer somehow.
- Back on original computer, replaced cable(s), re-loaded drivers once again (they were the very latest versions anyway) and re-checked everything I could think of; but no change - problem still exists!
So what's going on?
Out of curiosity and being at a bit of a loss, thought I'd check if there was an upgrade to SGP …. and there was (only small upgrade since previous version, but even so). So connected original computer to internet, downloaded & installed new SGP version and then tested again …
- Would you believe it, now the drivers seem to work just fine and load instantly as expected!! I've done nothing else new other than start up the latest version of SGP ...
Conclusion - SGP must have had a bug introduced on a more recent upgrade (this would explain why the issue suddenly appeared with no apparent reason) which would now appear to be resolved, and I'm a happy bunny again!
Thanks again for your guidance - so if anyone else has this problem, upgrade SGP to latest version first before diving in and changing any settings!
Richard
