Hi, is the ASIAIR PRO Supports the old Losmandy G11 Gemini 1 system?
and does tracking work?
What kind of cable is needed for the connection?
Thankful
Hello
Does anyone know the answer?
sajjad wrote: Hello Does anyone know the answer?
Hello sajjad, yes, it was supported. In ASIAIR app, choose option.
@asiair@zwo#39395 Will not connect to Gemini by usb under any baud rate.
Have you try running the USB-Serial cable in to the RS232 port on the control panel? I think this CPU panel uses LX200 commands. I’m using the same method to control my older LX90. It works so far. Click Sync Mount after everything is hooked up. Good luck.
Check this doc for connecting, https://www.facebook.com/groups/ASIAIR/permalink/1813700318793183.
