Is is safe to run a 13.8v DC regulated power supply as input to "12 volt" ports on Zwo products?
Most "12 volt" lead acid batteries are measure at 13+ volts.
Thanks!
Yes, it's safe.
Umm, Thanks. But how do you know?
The supply voltage range is safe between 11V-15V for ZWO cameras.
