Hello
Would it be possible to output the same control in the DSLR port as you have set for the ASI camera?
You could also control a DSLR when using an ASI camera. I have an Avalon M-Zero mount on which I can attach two telescopes. On the second telescope I have a DSLR attached. I can of course control the DSLR myself with a controlled remote shutter release or an internal timer - that's no problem. The problem is the dithering which I do with the ASI camera, and I don't want to deactivate it.
Of course I have to use the same exposure time on the DSLR as on the ASI camera, but it would be a compromise. You use the DSLR port only for triggering a DSLR which is not connected to the AsiAir via USB.
Would something like that be possible?
