I would like to use the mini EFW to swap my SA-100 Star Analyzer diffraction grating in and out of the optical path. It is in standard 1.25" filter format however the filter band is 7mm thick and the threads are 3 mm thick. This is exactly the max thickness that your manual says will work. Is there any room to spare or is this just too thick to work.
Thanks
