hi, I've just switched from a celestron AVX mount to the IEQ 30 Pro. I'm assuming that as I did with the AVX, I connect the mount to the ASIAIRPRO through the handset where there appears to be two RS232 jacks. Would I find a cable that plugs from there into the ASIAIRPRO's usb port or its phone-cord like jack (longer and wider than the RS232)? When I tried the standard RS232 at both ends, while it clicked into the ASIAIRPRO the software said it couldn't see the mount.
thanks for any help,
jeff
