Hi-
I see you have an older T2 tilt adjuster and a new one - but neither one would allow access to the screws while attached to a filter wheel - with a larger cooled camera.
I would like a similar adjuster that is perhaps 2cm diameter larger than the asi1600 so that the screws could be on the camera side and just outside the camera body. Is there a reason you don't want the tilt adjuster larger than the camera body?
If the thickness can be the same 11mm as the T2 extender I think this would be a popular item.
Thanks,
Frank
