I tried live stacking with the ASI AIR pro few days ago. I first took the darks and bias shots during the day. Before I started imaging I took the flats.
I then went in the program and selected all the options for darks flats and biases and selected the proper master frames from earlier.
I then started the session and also opted for saving all the separate files. When during the session I clicked on the options. All the boxes for dark bias and flat frames were unchecked. So not sure whether there was an actual correction taking place.
Also the separate lights that are saved, are they also corrected with flat bias and dark or do I still have to do that when stacking them.
I noticed a lot of small stripes (running noise) in the stack I made with no outlier correction. Really cool feature by the way!
Thanks,
Peter
