First question for this support group. I received my ASIAir this week. The usual bad weather came with it. I had researched a lot about this product and knew of a few issues but purchased it anyway. Right now my review would be mixed. A lot of things run flawlessly, others not so much.
I am about 3 years deep into AP so this isn't my first rodeo. In the past I have used APT, SGP and SharpCap Pro as capture/control programs. Guiding has always been done by PHD2. Have I had issues, you bet, but usually they can be fixed by taking new Dark files and re-doing the Calibration. My first session with the Air was a "let's see what and how it does it all.
PlateSolving worked as good if not better than any program I've played with. BUT, for the life of me the I can NOT get the thing to Calibrate the guiding. I saw no place for what the original PHD2 called Dark Library. I found a post on here about changing a setting for the Calibration Steps which I tried everywhere between the lowest to maximum. I changed the Gain on the guide camera....
The Goto works fantastic but without Guiding I am hooped!
My equipment is as follows:
CGEM Mount
SharpStar 61 EDPHII imaging scope
ZWO ASI533MC Pro imaging camera
StarField 60 guide scope
ZWO ASI120MM Mini guide camera
This equipment has a proven track record with the above equipment and APT or SGP as a capture/control program with PHD2 guiding giving me a total RMS in Pixels of .8 and under.
Hope someone can offer advice on what I am doing wrong!
