Hello,
I've recently plug my ASIAIR PRO on my astrophoto setup.
Everything works well : cameras, mount, focuser are detected (I love my ASIAIR !) but GOTO on my mount is inoperant.
The mount never move when I select a target or when Polar Alignment need to rotate by 60° (however star tracking is OK).
I've searched a fix on this forum but nothing work : disable daylight time saving, change RS232 cable, use sync button on mount panel, power on mount only after PA, do a platesolving before, set the mount on zero position, power mount with a dedicated cable...
One more thing : before ASIAIR I was use a stellarmate system and GOTO was OK and with GOTO mount hand controller too.
Here my setup :
- Ioptron IEQ45 #8406 with latest firmaware
- ASIAIR PRO
- ASI294MC
- Mini ASI290MM
- EAF focuser
Thanks for your help.
Beuq
