I can connect the startbook ten to asiair via LAN cable. But I fail to use skysafari connect to Starbook.
Is it support the safari bridge for vixen starbook ten? If yes. How can I configure it?
phy16250 wrote: I can connect the startbook ten to asiair via LAN cable. But I fail to use skysafari connect to Starbook. Is it support the safari bridge for vixen starbook ten? If yes. How can I configure it?
Yes, in SkySafair, you need to input the IP addr. of the SBT and use the port 80.
