>>The only thing was I reflashed the same micro card and it did an upgrade to latest version.
>> Do you think that its worthwhile doing on new virgin micro card?
Hi Gaby,
At this point, I don't know what else you can do other than contacting your dealer for a warranty return. I have not done it before and have no idea how long it takes. So, I think your idea of just acquiring a new Pro makes sense. But you can turn the non working one in for warranty exchange, and end up with a backup ASIAIR pro later.
If the only things in your system are 1) the ASIAIR Pro, 2) your router, 3) a single camera, 4) power supply and 5) the LAN and camera cables, there are not many stones left unturned.
Presumably you have already tried connecting a laptop to your router to confirm the router is OK. You have already tried two different ZWO cameras. You have tried different cables, and presumably the power supply voltage is normal (my PowerWerx power supply is a 30A unit that I have set to about 14.8 volts to compensate for the 10 meter 10 AWG cable).
If you have a USB 2.0 power meter (pretty ubiquitous at Amazon) you can plug it into one of ASIAIR's port to see if it is actually delivering 5.1V when unloaded. You can check the 5V at the Raspberry Pi GPIO port too, but that involves opening the metal case, and your dealer may use that as an excuse to void warranty.
>> I have a Tak106 which I'm preparing for full automation. On my Avalon M-Uno mount.
The only reason I did not go to an FSQ106 is that I can't carry it safely (I am old, and 5' 2" tall). The M-zero was actually one of the final mounts I considered when I transitioned from my old Tak EM-11 mount; that mount became too heavy to handle too as I got old. But decided to go with the RST-135 since it does not require counterweights, albeit tracking is inferior to the Avalon (especially M-uno). But it is good enough for my small telescopes.
Of course, now that M-zero (and probably the M-uno too at some point) as a motorized Alt-Az option, you can be fully automated even for touching up Polar Alignment from indoors :-).
>> I can now do it and polar align in 15min.
One thing I did in the past year was to get the William Optics Mortar tri-pier and leave both the RST-135 and tri-pier outdoors all the time (with two layers of waterproof "backpacks" covering the mount in the daytime :-). If I am careful not to move the mount when setting up and tearing down the OTA and guide scope, the polar alignment is within a couple of minutes of arc from night to night, and it takes 4 minutes flat to get the polar axis fine tuned.
>> Asiair wonderful for this kind of setup.
I agree completely. No more craning of the neck with polar scopes, or get bitten by mosquitos waiting for slow drift alignment, either. Or the need to go outdoors to refocus the telescope. Plate solving is icing on the cake.
INDIGO Sky and StellarMate could do the same things as ASIAIR, but with a messy jumble of disparate programs and drivers. They are just too un-integrated to be as appealing as the ASIAIR. I just hope that ZWO does not lose focus with their DSO beginnings, and start doing the "everything but the kitchen sink" approach too.
You stay safe too, Gaby.
