Does someone recognize this? When I make my subs I have in all my lights and flats a bright circle in the middle. I only have it when I make my light with the Asiair Pro. When I use Sharcap as capture software, all lights are ok.
This post may be deleted. I just have noticed that it is also in my subs with Sharpcap. :
Strange, I did a test with SGP and no circle is visible. Should this be a effect of the used software of the Asiaiar?
Huubke wrote: Strange, I did a test with SGP and no circle is visible. Should this be a effect of the used software of the Asiaiar?
Maybe it's caused by the optical error, try to calibrate see if it's still there in the stacked image.
