Hi ZWO
Yes, I use EQMOD between AsiAir and the mount. No handset
No problem ever with this.
What happens is I set an Autorun which finishes for example at 4.00 am
With AsiAir set to Goto Home and then Shutdown, all goes well, the mount stps tracking, all is calm but dew heaters also go off.
With ASIAIR set to Goto Home, no Shutdown, the mount kept tracking until I intercepted it before damage at 7.30am but the dew heaters are off so a very wet ASIAir.
Now I set home and shutdown for each autorun and I have re-routed my dew heaters so that they are fed directly, not via AsiAir and never go off. This means the telescope correctly is aligned, the camera cooling fan is off, tracking has stopped and I have no dew on the tube. I have made a flexible dew cover for the electronics and cameras and this helps too.
I would recommend that you allow Stop Tracking as an option for the Shutdown selection.
