Hi!
I have a big problem with the autoguiding function. I always have the problem that the star jumps away because the mount moves on purpose. Sometimes this happens during calibration, sometimes the autoguiding has been going on for a while with quite good results. Then the mount jumps in several directions and it loses the star.
- The mount is in balance.
- I have the ZWO OAG
- I use the ASI120MM Mini as a guidingcam.
- I use a SkyWatcher AZ-EQ6 mount
- I tried three different cables between ASI120MM mini and ASIAIR
- Restarting ASIAIR and Mount does not help
See here a example:
https://www.dropbox.com/s/vle4900xwbkan2u/20200912_220011.mp4?dl=0
I read in someone else's ASIAIR Facebook group that he has the same problem, also with an AZ-EQ6. Could this be a bug?
