Hi Markus,
ASIAIR v1.5 Beta has these two parameters under the Meridian Flip Settings in the Telescope Settings window:
Stop tracking x mins before Meridian
Do AMF x min after Meridian
Looks like they might be what you are looking for.
Because of smoke from nearby forest fires and now rain and clouds, I could only test the Beta indoors. Other than not completing the plate solving part of the auto Meridian flip in the daytime, it appears to work fine on my RainbowAstro mount, with both parameters set to 1 minute. The ASIAIR used to wait between 250 seconds to 450 second before doing the second step, and wasting valuable imaging time. (We will now waste valuable imaging time to do auto refocusing, ha ha -- incidentally, automatic refocusing has two parameters, Run Auto Focus in AutoRun every xº change (you need to buy the optional temperature probe), and Run Auto Focus in AutoRun every x hours).
I checked it by pointing the mount (indoors) at a star that is about to cross the Meridian, and can confirm that the ASIAIR report (in the AutoRun window) for "time before Meridian flip" agrees with the hour angle of the object in SkySafari, and it performed the two above steps (stops tracking at the first step, and issuing a GOTO to the mount to perform the second step) within a second of the correct times.
Since the Median Limit of my mount is set to 2 degrees, I could have set the first parameter to -1 and the second parameter to 0 to save even more time, but I thought that would be pushing my luck (and I wasn't sure ASIAIR would take negative numbers).
