A couple of things to check:
1) make sure focus is tack sharp,
2) if you are using a reducer or flattener, make sure you account for how its changes the focal length,
3) make sure there are no shadows of buildings or trees branches protruding into the frame (minor protrusions are often OK when the sky is very dark)
4) stay at least 30 degrees away from the poles.
5) try setting focal length to "0" and let ASIAIR figure it out for you.
A wrong back focus when using a reducer can also throw off the focal length value.
It is best not to give it a specific focal length the first time you try to plate solve. Set the focal length to 0 (yes, zero) and let the plate solver figure it out for you. A zero value will take a little longer to solve, since ASIAIR is doing a more extensive search. Once it succeeds, it will place the proper focal length into the focal length field.
