For the second time in a row, and the only times I’ve tried doing LRGB imaging with the new automated focusing (AF) feature, focusing failed. In fact it made the focus MUCH worse when AF “completed” re-focusing the scope between the last red-filtered image and the first green-filtered image.
(In case you’re wondering, I always start an imaging session by manually getting a good initial focus on a bright star using a Bahtinov mask.)
Also, there was no issue when AF did its thing before switching from the Lum to the Red filter.
These results came with Beta Release 6.69 and going forward I will update my app/ firmware to 6.71.
My automation script was:
Lum - 10 images, 120 seconds each
Red - 5 images, 120 seconds each
Green - 5 images, 120 seconds each
Blue - 5 images, 120 seconds each
My ASIAIR Pro is setup as follows:
DC Power-1---ASI183GT
DC Power-2---EAF
DC Power-3---Anti-dew Strip-1
DC Power-4---Anti-dew Strip-2
USB3/Top---Memory Stick
USB3/Bot---ASI183GT------Vixen Starbook10/Vixen SXP mount
USB2/Top---ASI290Mini------Vixen Starbook10/Vixen SXP mount
USB2/Bot---EAF
