Yes, indeed, by checking RAW data box solved the dropping frames issue. You really MUST release that bloody manual! Make it quickly! For now it's like you released the carriage (software), but you forgot the horses (manual)... I also saw that there was a big difference between files sizes, but I attributed it to the differences between SER vs AVI containers and used codecs.
As a suggestion, can you implement SER container also for RAW8? This is the most astronomical container ever, most compatible with astro editing softwares.
I also thank YOU. 😃 It's nice to have an alternative to Sharpcap and I'm very happy that ASIcap really works even better. Now I'll test the ASIlive, because, as far as I remember, there was also problems at it, too...
EDIT: I made some daylight tests using my little ED72 refractor, by targeting the AC of my neighbours 😃, about 50 meters away. The results are very good considering I didn't open the window. 😁 Now I wait for springtime to come, because here we always have clouds, in the winter...
