Hi,
I have an AZEQ5 with PPEC already trained. Using the ASIAIR EqMod telescope driver there is no option to set tracking to Sidereal + PPEC as on the HC. If I get a serial to usb cable for the HC and use the Skywatcher SynScan driver will this option become available?
By the way - if you ever release a firmware update where the beep at start up and shutdown can be disabled totally it would make my ASIAIR Pro perfect, I know when it's powered on because I can connect to it with the app :)
Thank you very much.
Best regards
Antony
