I've run into a problem while taking flats with NINA 1.10.HF1 (the latest version) on Windows 10. The camera is 2600MC Pro.
The problem: I can take flats with gain 115 or higher. If I lower the gain to 114 (without changing anything else), NINA reports SDK errors, as seen in the screenshot.
The exact sequence is as follows:
- connect camera to computer
- start NINA and connect the camera in NINA (note my default offset is set to 50)
- start Flat Wizard, set gain to 115
- initiate the wizard (note: you may need to adjust exposure or step settings, depending on your light source)
- the above should complete fine
- close NINA, disconnect camera.
- reconnect camera to computer
- start Flat Wizard, set gain to 114
- the above will give the errors seen in the screenshot
I've posted this on NINA's Discord support channel and they said it's a problem with the SDK and suggested I contact you.
Thanks and let me know if I can do anything else to help.
